Results 1 to 3 of 3
    Points: 546, Level: 4
    Aug 2016
    546
    Regarding .lis file generation in HSPICE.
    Hi
    When I simulate the .sp file using HSPICE, I get .ic0, .st0, and .tr0 files as a result after the simulation.
    May I know, why I am not getting the .lis file in addition to the above other mentioned files?
    Amit
    Points: 17,492, Level: 32
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,689
    17,492
    32
    Re: Regarding .lis file generation in HSPICE.
    You have to specify output logfile as option of hspice command.
    % hspice aho.sp -o boke.lis
    Aug 2016
    546
    Thanks a lot for your kind reply, it worked...
    I also found that another command, "hspice <filename>.sp > <filename>.lis" can also be used to generate .lis file.
    Just an additional thing, I would like to know that in the lis file details, the "Total CPU time" is shown as 0.00s (probably it is in ms). May I know, how can I look for the Total CPU time, if it is say is in "ms"?
