Page 2 of 2 FirstFirst 1 2
Results 21 to 27 of 27
  1. #21
    Points: 76,203, Level: 67
    Apr 2014
    15,455
    76,203
    67
    Re: Multiple relay with controllers
    Is this circuit is correct..?
    It does not work ... how can it be correct?
  2. #22
    Points: 80,457, Level: 69
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,182
    80,457
    69
    With R4, R9 and R13 replaced with a link it should work. As the schematic showed it, might have worked but the highest voltage you could get on U1 inputs would be half VCC (because of the voltage divider, example R4 and R1) less some extra voltage dropped by the transistor in the PC817. That might not be enough to ensure logic levels were satisfied. Personally, I would link out R4, R9 and R13 and also increase the value of R1, R2 and R10 to say 4.7K as there is no advantage in the extra current being drawn through them.
  3. #23
    Apr 2014
    15,455
    76,203
    67
    ...or use a HCT595...
  4. #24
    Points: 258,432, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,118
    258,432
    100
    For correct shift register operation, the clock signal has to to fulfill the maximum rise/fall time requirements of HC logic family. A standard opto coupler probably can't guarantee this, high load resistance values further slows down the edges. An ST clock buffer may be required.
    To save the useless series resistors?
  5. #25
    Apr 2014
    15,455
    76,203
    67
    No, just to minimize the count of modifications to the given schematic...
    There are so many ways and so many reliable and proven circuits available ... the OP could use.
  6. #26
    Full Member level 5
    Points: 1,963, Level: 10
    Sep 2016
    313
    1,963
    10
    Quote Originally Posted by venkates2218 View Post
    Attachment 153567
    Now it is correct..?
    Does series resistor is required between the PIC and shift register pins..?
    Is it ok to place an resistor of 470R in LATCH,CLOCK,SERIAL DATA path to the controller..?
  7. #27
    Apr 2014
    15,455
    76,203
    67
    Are you aware that you didn't show the 470 resistor in your schematic?
    Generally you are free to use as many resistors you like.
    The only thing you have take care is to satisfy the datasheet specifications.
