Results 1 to 7 of 7
    Advanced Member level 2
    Points: 3,530, Level: 13
    Feb 2016
    680
    3,530
    13
    Marchand balun layout
    For this marchand balun schematics in ADS, how to instruct the ADS layout generator to use coil shape (for area saving in IC) ?
    Besides, anyone have any experience with planar layout of marchand balun on PCB ?
    balun schematics
    generated balun layout not in coil shape
    balun layout in coil shape
    Points: 14,284, Level: 28
    Apr 2014
    2,239
    14,284
    28
    Re: Marchand balun layout
    1) ADS doesn't convert to physical layout (dimension) if your schematic has electrical parameters (impedance).
    2) If your schematic has straight coupled line, that is what you get in layout.
    3) There is no predefined layout element for such interleaved inductors, unfortunately.
    So there is a lot of manual layout work ahead.
    Feb 2016
    680
    3,530
    13
    Someone else told me to replace CLIN with 2 Symmetrical Coupled Microstrip Lines (MCP) and then use linecalc to get the correct length and width.
    What do you think about this idea ?
    Apr 2014
    2,239
    14,284
    28
    Quote Originally Posted by promach View Post
    Yes, that's fine, but it will be straight lines.
    Feb 2016
    680
    3,530
    13
    Yes, I am now trying to replicate planar layout of marchand balun on PCB using SonnetLite instead.
    This book Microstrip Filters for RF Microwave Applications has some good examples (maths theory + implementation) on microstrip filters, but not balun.
    Feb 2016
    680
    3,530
    13
    How do we see from the following expressions that even-mode to odd-mode impedance ratio is very important for balun ?
  7. #7
    Feb 2016
    680
    3,530
    13
    How to derive the expressions involving Ya, Yb, Zoe,Zoo ?
    And why need to increase Zoe/Zoo impedance ratio ?
