+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Junior Member level 1
    Points: 152, Level: 2
    Join Date
    May 2019
    Posts
    15
    Points
    152
    Level
    Problem with UART clock value in a VHDL sample code
    Hi, I'm using a VHDL code downloaded from GitHub to Drive a UART communication.
    Here
    I want to Use 250000 Baud Rate. So according to the top of VHDL file explanation, while my I_clk is 50MHz, I set:
    I_clk_baud_count <= X"00C8";--means 200
    it seems that the tx_clk should be 40us, but it is 40040ns in simulation.
    Is it wrong according to the code?
    Click image for larger version.
    •   AltAdvertisement
  2. #2
    Super Moderator
    Points: 84,013, Level: 70
    Achievements:
    7 years registered
    Awards:
    Most Frequent Poster 3rd Helpful Member
    Join Date
    Apr 2014
    Posts
    17,095
    Points
    84,013
    Level
    70
    Re: Problem with UART clock value in a VHDL sample code
    40040ns is about 40us. There is just 0.1% difference. Thus it's well within UART frequency tolerance.
    On the other side...with a 50MHz input clock you should be able to generate exactly 40000ns.
    Klaus
    Please don´t contact me via PM, because there is no time to respond to them. No friend requests. Thank you.
  3. #3
    Super Moderator
    Points: 266,518, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    46,584
    Points
    266,518
    Level
    100
    Problem is that the generated timings are off by one count. The code is reproducing a popular VHDL beginners fault.
    Instead of
    Code VHDL - [expand]
    if tx_clk_counter = 0 then
        -- chop off LSB to get a clock
        tx_clk_counter <= to_integer(unsigned(I_clk_baud_count(15 downto 1)));
        tx_clk <= not tx_clk;
    else
        tx_clk_counter <= tx_clk_counter - 1;
    end if;
    you want to write
        tx_clk_counter <= to_integer(unsigned(I_clk_baud_count(15 downto 1)))-1;
    else
    end if;
    or
    if tx_clk_counter = 1 then
    else
    end if;
    Hope the other coding is of better quality. My preferred VHDL flavour uses unsigned type both for the baud parameter and the counters, instead of std_logic_vector and integer, involving many type conversions.
    There are some problems involved with the code.
    red warning (likely to cause unexpected behavior) for using external input signal I_rx without synchronizing.
    yellow warning (causes difficulties with timing closure) for driving the transmitter with ripple clock I_rx instead of I_clk and a clock enable.
    •   AltAdvertisement
  4. #4
    Advanced Member level 2
    Points: 3,412, Level: 13
    Join Date
    Aug 2016
    Posts
    593
    Points
    3,412
    Level
    13
    Quote Originally Posted by matriX_1500 View Post
    At 250kbps, the tx_clk should be 1b/(250kb/s) = 4us and not 40us.
    I_clk_baud_count <= X"00C8";--means 200 . . . Nope
    I_clk_baud_count <= X"00C5";--means 200 . . . Yes
    --Akanimo.
    •   AltAdvertisement
  5. #5
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    46,584
    Points
    266,518
    Level
    100
    Post #1 picture actually shows 4.04 µs, 1% off. Period neither is nor should be 40 µs.
    Please reconsider
  6. #6
    Join Date
    Aug 2016
    Posts
    593
    Points
    3,412
    Level
    13
    Yes,
    I_clk_baud_count <= X"00C5"; gives exactly 4us.
    --Akanimo.
  7. #7
    Super Moderator
    Achievements:
    7 years registered
    Awards:
    Join Date
    Apr 2014
    Posts
    17,095
    Points
    84,013
    Level
    70
    True ... I didn't re calculate it.
    Klaus
    •   AltAdvertisement
  8. #8
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    46,584
    Points
    266,518
    Level
    100
    Don't see how. You can get an exact TX Baudrate of 250 Kbaud by setting the baud divider to 199 or 198 (X"00C7" or X"00C6" respectively). This way you are compensating the above discussed design error. The RX rate will be still incorrect, thus you better correct the design and use baud divider of 200 or X"00C8".
  9. #9
    Join Date
    Aug 2016
    Posts
    593
    Points
    3,412
    Level
    13
    1bit/250kbps = 4us
    50e+6/250k = 200;
    200/16 = 12 Remainder 5
    12/16 = 0 Remainder 12
    Decimal(12) = Hex(C)
    Decimal(200) = Hex(C5)
    Quote Originally Posted by FvM View Post
    Don't see how.
    For God's sake, I don't know how I got X"00C5" for 200 earlier on.
    I just recalculated and I got X"00C8". Sorry for the confusion.
    --Akanimo.
  10. #10
    Points: 6,599, Level: 19
    Join Date
    Feb 2015
    Posts
    1,065
    Points
    6,599
    Level
    19
    Quote Originally Posted by Akanimo View Post
    the decimal value is even, the hex value is odd.
