Results 1 to 3 of 3
    Newbie level 2
    Points: 49, Level: 1
    Feb 2019
    49
    Safe distance from Power MOSFET
    Hello friends
    Safe distance from the LCD to power MOSFET should be how much?
    And what is the standard for calculating this
    IRFP250
    Vds = 24 V
    Id = Max 4 A
    Vgs=15v
    Ferq = 10 KHZ
    Driver = IR2104
    Many thanks
    •   AltAdvertisment
    Points: 72,488, Level: 65
    Apr 2014
    14,734
    72,488
    65
    Re: Safe distance from Power MOSFET
    Hi
    The problem is not the "distance".
    Itīs the current flow and the impedance...that may cause error voltage.
    Easiest way:
    --> use a proper GND plane (one layer just for GND, no other signals) and use decoupling capacitors.
    •   AltAdvertisment
    Newbie level 2
    Feb 2019
    49
    Hi
    thank you but i want what is the standard for calculating this distance for reduce the error voltage effect
