Results 1 to 10 of 10
    Points: 47, Level: 1
    Mar 2019
    7
    47
    Power amplifier delta and K factor <1
    Hello, iam design power amplifier, but my delta and K factor is less than 1 What should I do ?
    •   AltAdvertisment
    Points: 496, Level: 4
    ArakelTheDragon's Avatar
    Jul 2017
    If you like the post, please press "Like".
    38
    496
    Re: Power amplifier delta and K factor <1
    Can you please give us a circuit. Sometimes its hard to translate these questions in English.
    If you liked the post, please press "Like".
    Points: 28,654, Level: 41
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,532
    28,654
    41
    Blog Entries
    In general people give indication of what their are referring to.
    We can assume that you are talking about the loopback gain of a control system.
    Being the case, have a look at Barkhausen stability criterion.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    •   AltAdvertisment
    Mar 2019
    7
    47
    , i would to design the power amplifier with transistor CREE CGH40006S if i want to matching impedance is always not matching ,does it affect the stabilizing circuit? because I just give arbitrary resistive value at the input?
    Thanks for your explain, but iam sorry i didnt understand
    •   AltAdvertisment
    Nov 2006
    Brazil
    8,532
    28,654
    41
    Blog Entries
    We neither.
    Draw some sketch and/or spent more time to depict the "stabilizing circuit".
    Points: 343, Level: 3
    Jan 2019
    51
    343
    Quote Originally Posted by Fhadz View Post
    I did not completely understand your question but I am going to go out on a limb and try to guess it.
    So you had a transistor, and you found that your Rollett stability factor is less than 1. And you want to know what to do?
    K>1 means unconditionally stable but K<1 does not automatically imply your amplifier is going to be unstable. It depends on your load and source impedance. If your load impedance is fixed, you can draw the load stability circle and see if your amplifier is going to be unstable for the load impedance that you are targeting. If no, then you should be fine.
    But if yes, then the only thing you can do it place a series resistor with the gate of your device to reduce the gain and see at what point your load lies outside your load (in)stability circle.
  7. #7
    Mar 2019
    7
    47
    Quote Originally Posted by vivekroy View Post
    is the addition of the resistive component the value free without calculation? and I have tried inserting a series resistive component but the MAG becomes small?
  8. #8
    Jan 2019
    51
    343
    Its kind of hard to do hand calculation. I typically sweep the value of R until I get Kf>1 and I use that value.
    But yes indeed, your maximum available gain (MAG) will come down.
  9. #9
    Mar 2019
    7
    47
    How to use typically sweep the value R in ADS? And the resistif componen always seri ?can i use the pararel?
    •   AltAdvertisment
  10. #10
    Jan 2019
    51
    343
