[SOLVED] SIM800 EAT compiling
dp1311.dp
Junior Member level 2
hello
i am using sim800c and i want to use sim800's gpio,adc, and other features for that i have downloaded sdk files from **broken link removed** and followed the guide as per attached document
while i am running the SIM868M32.bat file from windows command prompt i got the error " /usr/bin/sh: E:DevyaniGSMSecuritySystemSIM800SDK_1418B01SIM868M32_EAT/output/log/output.log: No such file or directory" as the slashes are removed from the path,and output files are not generated in output folder i am also attaching the screenshot of CMD
how can i solve this?
  • SIM868 Series_Embedded AT_Compiling Environment_V1.00.pdf
seems that you have to edit 'sim868m32.bat' file for your environment.
no i didnt
i have just extract the files and run them from the CMD
what changes should i have to make??
The error includes '/usr/bin/sh' which is a linux shell command.
Under windows it is not valid or you must have the cygwin to execute that.
cmd line figure attached , says that 'usr/bin/sh' error
So the original bat file was written for linux and modified for windows or armgcc used for cygwin environment.
hello
there was problem in java files or something else of my pc, still not able to find the problem
but i used other windows 7 pc and the file is compiling now
thanks
