FPGA Module with 12 bit ADC
engr_joni_ee
Advanced Member level 3
Any suggestion on FPGA development board having 12 bit ADC ? the cheaper one !!
If I´d look for something like this...
* I´d give a list of preferred FPGA manufacturers (are you really free to choose any manufacturer and any FPGA of random complexitiy? What about availability?)
* I´d give ADC specifications, like voltage range, sampling rate, precision...
currently on ebay (this link may time out):
Manufacturer: Xilinx
Analog Signal: 10 KHz signal, 0-3 V
ADC Sampling: 100 KSPS
I would go with #3.
Get the artix 7 board, then all your other projects can be build on the use of pmod
Thanks for suggestion. I guess Cmod A7 has USB-UART and USB-JTAG Programming Circuitry bridged on a single micro USB port. Is that right ? but is UART capable to send 100 Kilo Sample Per Second ?
