POL8437
Newbie level 2
Induction heater IR2184 overheating H-bridge
Hello,
I'm currently building an inductive heater, basing on the attached schematic. It's a slightly modified version of the neon-john heater (neon-john.com/Induction/heater.htm) and dandyk (danyk.cz/induk3_en.html). My resonance frequency is about 271kHz.
Sadly I have a few problems with this circuit.
1st of all, it worked once, when the coil L3 was 6.8µH/20A and supply voltage ca. 70V. When supply voltage was driven higher, the L3 coil was getting extremely hot. Then I decided to change to choke for a bigger one. I used a core TX32/19/13, made of 3E25 material. I made 3 turns at this core, so inductance was about 130µH (measurement was done at 100kHz). From this point, the circuit doesn't work anymore. IR2184 delivers signals to gates, but nothing more happens. What makes my life much more complicated, is fact, that when I'm trying to make any measurements with my oscilloscope, main fuse in a room (B16 :shock: ) is falling down. I suppose there is some problem with PE/N line :???: The main voltage (+300V) is supplied from regulated autotransformer.
2nd - IR2184 is getting really hot. When I put 3k3 resistors instead of gates, the supply current of IR2184 is about 70-75mA. When I connect the gates, it's rising up to 110-120mA (!). Does anyone have an idea, why IR2184 is getting the temperature like 80°C? Now also SD input has +15V. Should I change that to +5V That was mentioned in given below topic:
https://www.edaboard.com/showthread.php?288782-use-of-ir2184-to-igbt-inverter&highlight=ir2184
Best regards from Poland!
Hello,
