BLDC driver with and without FOC
aminpix
I am trying to design and implement a BLDC motor (2000 watt) with hall sensor. The motor has hall sensor. The new driver should implemented with FOC.
Before I had some experience with BLDC motors without FOC. (using STM32F030)
I wonder the schematics of the BLDC driver with FOC and without FOC are identical ?
A BLDC not necessarily needs FOC.
It's not clear if you need RPM control at all.
It's not clear if you need a microcontroller at all.
The more information you give the better and faster response you get.
Klaus
