Driver implementation for a modular SG DMA IP of Altera FPGA ?
hcu
This question correctly relates to this thread, I believe
I am writing a driver c code for altera fpga modular scatter gather DMA. where i have to decide the number of descriptors (that contains read address, write address, length of transfer and control field) and then i have to pass these descriptors to a list(may be linked list) using HAL API's given in the driver code (c file that is available in sdk bsp).
some how i have to use these below API's(these api function calls given in attached file) to perform successful data transfer from one place to other .
alt_msgdma_construct_prefetcher_std_descriptor();
alt_msgdma_construct_preftecher_std_mm_to_mm_descriptor();
alt_msgdma_prefetcher_add_std_desc_to_list();
alt_msgdma_prefetcher_set_std_list_own_by_hw_bits();
alt_msgdma_start_prefetcher_with_list_addr();
alt_msgdma_start_prefetcher_with_std_desc_list();
I think it needless to describe about hardware configuration(qsys soc integration) and all here. i am attaching both given driver file and the application file(upto what i written). please someone go through and show me the way. intel fpga forum(former altera forum) is horrible now , many of you know that.
In the given application file, i have taken 3 descriptors and want to pass these 3 to a single list and then use other following api's to do a data transfer. but i am failing
Regards,
Anil
  • altera_msgdma.c.txt
  • altera_msgdma.h.txt
  • app.c.txt
