Synaps3
I have an FM transmitter with integrated PLL and VCO synth. I want to use the transmitter on a lower frequency. Is there any easy way to divide the signal by 2?
I have another chip that has a built in divider that outputs a square wave. If i use the divider function of this chip and modulate the vtune pin, will the modulation on the divided frequency be distorted or will it sound the same as the fundamental?
