Light lit when motor rotate
PA3040
Advanced Member level 3
Dear All Have a nice day
I make a line follower robot using Arduino Nano and TB6612FNG Motor driver. It is working but only issue is when the motor rotate manually that power goes to LED near 7805 regulator . please advice how should I manage to stop it
my reference schismatics is attached
I am using LM2695 regulator instead of the schismatics power supply
Please advice
Thanks in advance
  • 3pi-schematic.pdf
I think the schematic may be incomplete or someone threw a few blocks onto a screen and left them that way, also there are multiple pins connected to thin air for example.
Do all you uC people have some issue with drawing a normal schematic that isn't painful to interpret? I'm beginning to think so. ;)
At least it's not some clipped nonsense where all the poster shows is 1 input pin and nothing more yet asks for help because the circuit's a company secret.
I'm guessing that if this is your circuit and you don't know how to remove the LED with no name near a 7805 with no name - Are they (hopefully) D5, the one near the I think it's a 7805 with no label? - maybe no one else can help either.
What is the LED doing? Is it just a visual indicator to show the boost is on or is it some kind of minimum load for the boost converter or is the LED there to do something else? What is the 5.1V Zener needed for - is it really necessary to drop a few volts for an LED or is it some kind of protection?
Simple solution, without knowing what function D5 has - remove it and calculate a dropping resistor to drop the equivalent voltage or put a few 0.7V diodes in series to make up the voltage drop of the LED.
Reactions: PA3040
    PA3040
When you spin an ordinary motor manually it becomes a generator. Evidently it produces enough voltage such that it travels back through circuitry, to light an LED.
Reactions: PA3040 and d123
    d123
    PA3040
I hadn't understood how literally they may have meant rotate manually. Thanks.
Reactions: PA3040
    PA3040
Hi PA3040,
Between the schematic and Brad's observation: What about a Schottky diode at the output of the 7805 blocking the reverse voltage (if actually generated by hand turning the motor) if a few 100mVs can be spared? Is the motor a 5V one that will work fine with ~4.6V?
Reactions: PA3040
    PA3040
Dear All Thanks you very much for the replies
Please see the attached block diagram which is about my robot , Can we able to identify the solution to the issue i explained in my first post
When I rotate motor manually both LED light up .What is the best solution that we can apply
Please advice
May I ask:
* why you rotate the robot manually? --> don't rotate it
* and what's the problem of light up LEDs in this case? --> don't care about the LEDs
Dear Klaus Thanks for the reply
I this it is poor design . Some lack of engineering
Please and engineering solution
I agree with Klaus, so don't rotate it ;) I guess this need is about predicting and protecting against what users may do with the device when left unsupervised by responsible adults.
Right now, rather than LEDs lighting up I'd worry more about sending a reverse voltage through drivers and regulators, especially the 7805 which isn't designed for that.
Not sure what the motor driver does so this is just from looking at the schematic you posted. Again, tried and tested solutions: put Schottky diodes from the two regulator outputs to the driver supply pins. Alternatively, maybe try diodes on the driver outputs and in this way block the reverse voltage from going through the driver back to the LED; it should work unless there's a polarity reason why that can't be done.
I can´t see this.
Tell me if I´m wrong: The robot is made to move by itself. So moving it by hand is mistreating the robot.
Railway level crossing accident due to careless drivers . So we can't tell them stop cross the track while train is coming but we should give a solution . My case is not like that but as a engineering body we should have a solution
One solution as per d123 pointed out, a schottky diode apply output of regulator
Hope more solution
