ejcmos
Newbie level 3
LDO pass transistor layout floorplan
Hi all,
I am designing a LDO as second power for a loading block.
The pass transistor is very large for supplying high current.
and also the loading block is very wide.
For the layout floorplan,
Should I distribute the pass transistor to surround the loading block to reduce the IR drop and the feedback line is very long, or concentrate the pass transistor in one place and close to LDO block and also enlarge the power line.
What's the consideration ?
Thank you in advance.
Hi all,
