Results 1 to 13 of 13
    Newbie level 6
    Points: 91, Level: 1
    Jan 2018
    14
    91
    How to control stepper motor rotation using voltage
    Hello all,
    I have designed a voltmeter circuit to measure 0 to 5V. I want to display the output on analog display that is, using dial display. For this I plan to use stepper motor to move pointer to correct position. The setup looks as shown in image: Click image for larger version.
Name:	x25 motor.jpg
ID:	143826. I have written a program to rotate the motor depending on the voltage measured. It doesn't show any error in compilation but when I try to execute the pointer does not move as it should. I have checked voltmeter circuit and it is fine.
    The code snippet is attached hereprogram.pdfprogram.pdfClick image for larger version.
Name:	x25 motor.jpg
    Srinidhi
    Points: 245,621, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,666
    245,621
    100
    Re: How to control stepper motor rotation using voltage
    The stepper pulse pattern doesn't seem to match the hardware configuration (motor connected by 3 wires). Show your circuit schematic and motor datasheet.
    •   AltAdvertisment
    Points: 71,898, Level: 65
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    11,774
    71,898
    65
    Indeed, the software seems to output 4 unipolar signals which would require 5 connections to the motor (4 + supply) so how do you have it wired with only 3?
    Newbie level 6
    Jan 2018
    14
    91
    Below attached is the circuit schematic. Output of voltage divider is given to an ADC pin of Atmega16. stepper motor is connected to micro-controller via L293D motor driver.Click image for larger version.
    Points: 61,770, Level: 60
    Apr 2014
    12,595
    61,770
    60
    Your circuit:
    GND symbols aren't expensive. Use them to avoid lengthy GND wiring...this makes the whole circuit more easy to read.
    Please dont contact me via PM, because there is no time to respond to them. No friend requests. Thank you.
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,666
    245,621
    100
    Let me put it this way: The circuit schematic (controlling 3 of 4 L293 outputs with connected bipolar stepper motor) neither fits the code (controlling 4 outputs PB1 - PB4) nor the stepper motor photo.
    What did you actually test?
    •   AltAdvertisment
  7. #7
    Points: 14,144, Level: 28
    Nov 2012
    2,619
    14,144
    28
    Stepper motors have more than three wires: your photo shows only three wires.
    I do not know how L293 is being used as a stepper motor driver.
    Is your motor BLDC type? Then you will need motors with Hall sensors or encoders...
  8. #8
    Newbie level 6
    Jan 2018
    14
    91
    It is stepper motor X-25. Datasheets of these motors are hard to find. one of the datasheet I found is attached below.X25 datasheet.pdf
  9. #9
    Newbie level 6
    Jan 2018
    14
    91
    I referred to the following webpage for interfacing stepper motor, l293d and amicro-controller: http://rickruling.blogspot.in/2013/1...tor-using.html
  10. #10
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,666
    245,621
    100
    Not exactly. There's one phase missing in your schematic and the code is accessing the wrong port bits, PB1 - PB4 instead of PB0 - PB3. Also the 3 wire stepper motor photo seems confusing. Is it actually a 3-phase motor (very unusual, but possible)?
  11. #11
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    11,774
    71,898
    65
    The motor puzzles me too. Note that the shaft is off center, that usually means there is a gearing mechanism inside it. It certainly doesn't look like a stepper motor and if it is a 3-phase AC motor I've never seen one so small and I can't think of a practical application for one that size.
    Drmius, can you show us more information about the motor or at least upload a picture of the other side showing any markings on the connections.
  12. #12
    Newbie level 6
    Jan 2018
    14
    91
    Below attached is the datasheet on X-25 motor. Basically these are stepper motors used by GM for instrument Clusters.
    •   AltAdvertisment
  13. #13
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    11,774
    71,898
    65
    That explains what it is but not why you only have three connections to it when it needs four.
    Beware of visiting Junken's web site, it pops up a "Windows Defender" virus alert and warns me not to shut my computer down and to call a support phone number immediately. The funny thing is - I use Linux!
