Results 1 to 6 of 6
    Points: 12,234, Level: 26
    Created Blog entry 7 years registered
    thannara123's Avatar
    Jan 2010
    Nedumkandam, India, India
    1,428
    12,234
    26
    Blog Entries
    DSP-Controlled On-Line UPS OLED shows Bypass NO Output
    Any body know the following online UPS .
    See the picture below
    The LCD display shows input 230 volt frequency 50Hz
    Buy No Output
    Shows Bypass anybody there to be help me ?
    some thing here http://http://circuits-collection.bl...d-on-line.html
    I Respect You
    •   AltAdvertisment
    Newbie level 5
    Points: 500, Level: 4
    Apr 2015
    8
    500
    Re: DSP-Controlled On-Line UPS OLED shows Bypass NO Output
    Cannot see unit pictures, any advice on model?
    •   AltAdvertisment
    Points: 27,344, Level: 40
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,180
    27,344
    40
    Blog Entries
    Your questions as usual lack of a better elaboration or at least less sloppiness: The attached picture is totally useless in the sense that it is impossible to read the silk legend on the top of the board. Another thing is that in the title says "bypass-no-output" but in the body of the post it is presumed you said "But-No-output" which are different scenarios. Also the link is dead, but you should already know.
    Anyway, back to the question: What have you measured so far? Is there voltage at the input and not at the output? If the only device between both would be supposedly one of the Relays, have you measured it to know if it is switching and has electrical contact ?
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    •   AltAdvertisment
    Jan 2010
    1,428
    12,234
    26
    Blog Entries
    Quote Originally Posted by andre_teprom View Post
    The online UPS OLED shows AC input voltage 230volt ,The Mode is BYpass mode But there no Output . I will upload more details tomorrow
    I Respect You
    Nov 2006
    Brazil
    8,180
    27,344
    40
    Blog Entries
    No need to upload more pictures, the only thing you have to do is to measure backwards from the output to input, checking where exactly the contact is interrupted. The by-pass operating mode is as simple as it could be, usually only one relay is what detaches the output from the input.
    •   AltAdvertisment
    Jan 2010
    1,428
    12,234
    26
    Blog Entries
    I Respect You
