frederic.naud
Newbie level 1
Hello,
I want to trigger a 24V circuit using a 12V signal. To do so, I thought about using a regular 12V relay triggered on pin 86 with a 12V signal and have my 24V circuit on pin 30 et 87. Will that work?
If not, will the same idea work on a 24V relay?
And if not not, does that kind of relay where the coil and the switch aren't at the same voltage exist?
Thanks in advance.
Fred
Thanks in advance.
Fred
