brunope
Newbie level 5
Hi guys,
When running the RC extraction with Encounter at the end of the PnR flow, I get the following messages:
**ERROR: (ENCEXT-3423): Detected 2 nets with incomplete RC network. Low-value resistances have been added by the software to complete the RC network of these nets. Review the list of affected nets in the 'ctrl_top.rc_typ.incomplete_res.net' file to ensure they are not along the critical path because results of timing analysis performed on nets with incomplete RC network can be inaccurate.
This happens only on 2 nets, that have nothing special from a design point of view.
Looking at the man of (ENCEXT-3423), this appears because the resistance for the given nets is not found in the SPEF.
But I am kind of stuck in tracing back the root cause of this problem.
Would you have hint about where to look?
Thanks!
Thanks!
