Results 1 to 7 of 7
    Junior Member level 3
    Points: 433, Level: 4
    Jul 2016
    28
    433
    PWM for LED module to choose duty cycle
    Hi friends,
    I driving LED with this TI's driver
    http://www.ti.com/lit/ds/symlink/tps92512.pdf
    I'm trying to write a code with PWM dimming control.
    According to the datasheet the dimming range is 100Hz to 1kHz(Pg. 12)
    In pg. 17 they give an example to a design with oscilloscope images(pg. 20) (PWM signals)
    I try to write a code with the ability to choose duty cycle to work with.
    (My board connect to outside CPU to select duty cycle thru I2C)
    attached a little clock diagram.
    I really need help here guys...Click image for larger version.
    •   Alt28th May 2017, 14:22
      advertising
    Points: 26,878, Level: 39
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,059
    26,878
    39
    Blog Entries
    Re: PWM for LED module to choose duty cycle
    I can't see your code.
    I can't see your math results.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    •   Alt28th May 2017, 14:57
      advertising
    Points: 71,480, Level: 65
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    11,698
    71,480
    65
    Nobody can help you if we don't know what happens in the CPLD.
    You are putting I2C data into it and presumably it produces PWM output to the TPS92512 but we have no idea how you want it to operate internally or if it does other jobs as well. Are you asking for the hardware design of an I2C interface and pulse width modulator and if so, which CPLD and which language?
    •   Alt28th May 2017, 22:56
      advertising
    Jul 2016
    28
    433
    Hi guys,
    I'm sorry about the ignition and my lacking explanation/information...
    Ignore the previous messaging.
    Again. excuse me about it.
    i try to drive PWM dimming for the LED driver above.
    I attached only the PWM code and not entire the code.
    I wrote the code but after i ran test banch, i saw my PWM frequency is 40 Hz instead 1kHz and my duty cycle (PWM_SW) work fine.
    I need help to find my mistake in the code. why i see 40Hz and not 1kHz..
    I decied to work with state machine.
    Also, i add image for my simulation
    1kHz clock generate at my "top" design.
    Thx u a lot guys!!
    Code VHDL - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    59
    60
    61
    62
    63
    64
    65
    66
    67
    68
    69
    70
    71
    72
    73
    74
    75
    76
    77
    78
    79
    80
    81
    82
    83
    LIBRARY IEEE;
    USE IEEE.STD_LOGIC_1164.ALL;
    USE IEEE.STD_LOGIC_ARITH.ALL;
    USE IEEE.STD_LOGIC_UNSIGNED.ALL;
    USE IEEE.NUMERIC_STD.ALL;
    ENTITY UV_PWM IS
        PORT(
            MCLK        : IN    STD_LOGIC;
            RESET       : IN    STD_LOGIC;
            UV_ENABLE   : IN    STD_LOGIC_VECTOR(2 DOWNTO 1); ---- ENABLING the 48V ON BOARD
            PWM_SW      : IN    STD_LOGIC_VECTOR(6 DOWNTO 0); ---- SOFTWARE IDICATES WHICH PWM WILL OPERATE
            CLK1KHZ     : IN    STD_LOGIC;-------------------- 1KHz WILL CONNECTED AT MY TOP
            UV_DIAG     : IN    STD_LOGIC_VECTOR(3 DOWNTO 1);   ---- IGNORE IT, SOME INDICATION ON MY CIRCUIT
            PWM_ON      : OUT   STD_LOGIC );    ------- PWM SIGNAL OUTPUT TO THE DRIVER
    END UV_PWM;
    ARCHITECTURE ARC_UV_PWM OF UV_PWM IS
    SIGNAL  PWM_CNT         : STD_LOGIC_VECTOR(6 DOWNTO 0);----- 100%---64h----1100100b
    SIGNAL  CLK1KHZ_O       : STD_LOGIC;
    SIGNAL  PWM_SW_I        : STD_LOGIC_VECTOR(6 DOWNTO 0);
    TYPE    STATE IS (STATE1, STATE2, STATE3, STATE4);
    SIGNAL  NS            : STATE;
    BEGIN
    PROCESS(MCLK,RESET)
    BEGIN
        IF RESET='0' THEN
            PWM_CNT <=  (OTHERS=> '0') ;
            PWM_SW_I <= (OTHERS=> '0') ;
            PWM_ON  <= '0' ;
        ELSIF (MCLK'EVENT AND MCLK= '1') THEN
            CLK1KHZ_O  <= CLK1KHZ;
            PWM_SW_I <= PWM_SW;
            -- IF UV_ENABLE = "11" THEN
                IF UV_DIAG = "000" THEN
                    IF ((CLK1KHZ = '1') AND (CLK1KHZ_O = '0')) THEN
                        CASE NS IS
                            WHEN STATE1 =>
                                IF PWM_SW_I = "0000000" THEN
                                    PWM_ON <= '0';
                                    NS <= STATE1;
                                ELSE
                                    NS <= STATE2;
                                END IF;
                            WHEN    STATE2 =>
                                IF PWM_CNT < PWM_SW_I THEN
                                    PWM_ON <= '1';
                                    PWM_CNT <= PWM_CNT + 5 ;
                                    NS <= STATE2;
                                ELSE
                                    NS <= STATE3;
                                END IF;
                            WHEN    STATE3 =>
                                IF PWM_CNT < "1100100" THEN
                                    PWM_ON <= '0';
                                    PWM_CNT <= PWM_CNT + 5;
                                    NS <= STATE3;
                                ELSE
                                    NS <= STATE4;
                                END IF;
                            WHEN    STATE4 =>
                                IF PWM_CNT = "1100100" THEN
                                    PWM_CNT <= (OTHERS => '0');
                                    NS <= STATE1;
                                END IF;
                        END CASE;
                    END IF;
                END IF;
            END IF;
        END IF;
    END PROCESS;
    END ARC_UV_PWM;
    Points: 244,817, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,519
    244,817
    100
    How can you expect 1 kHz PWM frequency if you are advancing the PWM counter at only 1 kHz? You get PWM frequency = 1 kHz/number of pwm counter states
    Jul 2016
    28
    433
    Sorry.
    I did not understand u.
    You meaning i have 10Hz pwm frequency?
    the cntr i try to do is for 0-100% duty cycle from 1kHz..
    PWM_ON is the output after calculating that.
    •   Alt14th June 2017, 15:58
      advertising
  7. #7
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    42,519
    244,817
    100
    You have 20 + something pwm counter states by increasing the pwm counter by 5.
    I really don't know what I should explain more, the behavior is completely obvious when you look at the simulation. Just don't understand why you expect 1 kHz pwm frequency.
