Transient Analysis with AMS gives error
ashrafsazid
Germany
I have an ADC test bench where I have some transistor level blocks and one ctrl block. This CTRL block is written in both Verilog-A and Verilog-D code. when I perform an spectre simulation The ADC_testbench simulation is running okay, but when try to run it on AMS it gives the following error. N.B for ams simulation I am using verilog-D model of ctrl block and that didnt give me any parsing error.
Describe correctly
It can't be true.
Cadence Spectre can not treat Verilog-D.
Attached log is of Cadence Spectre.
I can not understand what you want to mean at all.
Hi, this are the attached figure. you can see there are several blocks. top level- input signals (verilogA) and ADC (has many subblocks, subblocks are CTRL, DelSIg, COI). Delsig - on Transistor level, CTRL & COI - has both verilogA and VerilogD.
When I run spectre, it takes verilogA model, and the whole testbench running fine without any error.
The verilogD codes written for CTRL and COI is tested with a testbench on Aldec Riviera, there it ran fine. Even when I generated a functional block for that CTRL & COI block on Cadence it gives no error during parsing (check and save) of the code.
So, when I start running an ams simulation in cadence configuring that CTRL & COI will run in VerilogD and Input in verilogA, Delta-Sigma on Transistor level, then I find some error regarding convergence problem, I assume that comes from analog/digital interface of the signal. But I tried changing timescale on VerilogD codes the problem doesnt solve.
Show me configuration view for the following states.
(1) For pure Spectre Simulation
(2) For AMS Simulation(Cosimulation between Spectre and NCSim)
There is no relation to timescale.
Do you surely set appropriate values for AtoD and DtoA ?
BTW, why do you short output bit buses ?
Output of COI is out<18:0>.
However you connect it to one node out.
I think COI is Decimation filter by CIC.
For pure spectre simulation there are no such config created- only a schematic view with schematic symbol for Delsig, VerilogA models for other block, then check and saved, then from ADE L, transient simulation is performed.
These are the config views for AMS.
I dont have idea about the- set appropriate values for AtoD and DtoA
The COI is just cascaded integrators simpler than CIC. the outputs are shorted, and hence the output pin is changed to inout so that this warning becomes suppressed.
@pancho_hideboo can you please tell me how to set the values for AtoD and DtoA
