You see loop gain indicated in an amplifier open loop gain diagram. The point "way down" is unity gain frequency.
Feedback factor < 1 is the missing link. Read the text completely beyond the quoted part.
It's 0 dB open loop gain. Or -xx dB loop gain, depending on the feedback factor implemented in the circuit.how many dB is that for unit gain frequency?
Loop gain is not the same thing as open loop gain, and the frequency for loop gain of 0 dB isn't necessarily the same as the frequency for open loop gain of 0 dB.
Referring to the diagram in post #1, I'm only guessing the "other point" could mark open loop gain of 0 dB. Because the diagram is missing a clear annotation, it might be anything.
You should:
- review your text books about the difference between loop gain and open loop gain
- get (or sketch yourself) a completely annotated bode diagram
If you carefully look onto the first diagram you will notice that at wo the label is "loop gain" (neither open-loop gain nor closed-loop gain).
In the diagram in post#1 the axes are not labeled with numbers. We shouldn't automatically assume that the omega axis is at 0 dB. In a lot of Bode plots you see the omega axis at some arbitrary location far below anything else so it doesn't clutter up the diagram. It's a matter of convenience. This may be look odd if you're used to cartesian coordinates where the axes intersect in the point (0,0). The axes in a Bode plot don't intersect at 0 Hz either because you can't draw 0 Hz on a log scale.
In the diagram loop gain is labeled x and is drawn as the distance between the magnitude curve and the broken line. So 0 dB is where the broken line is.
The point marked "what's this point" is just where the omega axis in the diagram happens to be. The point marked "Loop Gain = 0 dB" is in the right spot.
Having the magnitude axis origin at 0 dB is in fact the standard, but not guaranteed.then why so many bode plots I run across shows 0dB at same level as the omega w axis? Look at diagram at post #8.
