+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Newbie level 2
    Points: 21, Level: 1
    Join Date
    Jul 2016
    Posts
    Points
    21
    Level
    HFSS newbie help - wave ports and feeding - E Field becomes 0
    Hey all, im learning to use HFSS and im facing a bunch of problems with wave ports and feeding. After a few tries i cant make work my design so i beg for help :P.
    My problem is that the E Field becomes 0 before reaching the surface which is a perfE. The feeding line is "pec".
    Any idea how to solve this?
    Click image for larger version.
    I dont know if i have explained what my my problem is clearly. Also sorry for english, not native.
    •   AltAdvertisement
  2. #2
    Full Member level 5
    Points: 3,186, Level: 13
    Achievements:
    7 years registered Created Blog entry
    Join Date
    Jul 2007
    Trieste
    Posts
    285
    Points
    3,186
    Level
    13
    Blog Entries
    Re: HFSS newbie help - wave ports and feeding - E Field becomes 0
    What you mean by feeding line is PEC?
    If you want to define the port then that face must not be PEC.
    You can use tutorials about how to define PORTS in HFSS.
    I tried to answer what i get from your post.
    Explain further if you have issues
    1 members found this post helpful.
    •   AltAdvertisement
  3. #3
    Newbie level 2
    Join Date
    Jul 2016
    Posts
    Points
    21
    Level
    Just re-did my design following a tutorial, made only few changes but now works fine. Thank you buddy nomigoraya.
    •   AltAdvertisement
  4. #4
    Full Member level 5
    Achievements:
    Join Date
    Jul 2007
    Trieste
    Posts
    285
    Points
    3,186
    Level
    13
    Blog Entries
    CST has very well elaborated and active online help system if you use the legal software
    In case of HFSS it is not the case but still type the issue in Google and i am sure you will find lot of help material and examples.
    The best way is always to start with tutorial
