sine wave signal oscillator
RITESH KAKKAR
Banned
INDIA
Re: sin wave signal oscillator
1. Pick BC547B or other real transistor instead of using generic NPN
2. Skip initial transient solution in simulation command (UIC option) for reliable oscillation start
The circuit dimensioning is apparently far from optimum. Changing the 470 nF capacitor to 100 nF makes it work also with generic NPN.
Hello,
It is working how it is generating SIN wave?
I do not see how the circuit can work. The transistor is biased completely wrong and is saturated.
I am simulating it with a very low input level and a fairly high input level:
EDIT: Oops! I did not notice that the 12k resistor connects to the collector.
for learning.
OK - good reason.
My recommendation: Start with feedback circuits, the definition of "loop gain" and the criterion for oscillation (Barkhausen criterion)
