How to charge an empty 6V VRLA battery?
Sunny55
Full Member level 3
Hi guys,
I need help here to top up the charge on a 6V 1.3Ah empty VRLA battery.
Whats the voltage & current i should be using to charge the battery?
Here's the battery information:
Constant voltage charge
Boost/equalize: 7.2 - 7.5V
Float: 6.75 - 6.9V
Max charging current :0.39A
I am using an LM317 adjustable voltage regulator to set the charging voltage.
Thanks,
Sunny55.
A state machine with flip flops is simple to control these 3 states. plus Vbat present.
Use a current sense R such as 75~ 100mV at max current.
Use a band gap ref for controlling current , voltage and shutdown float, which is included in LM317, but using a linear regulator is very inefficient with heat sink required.
Measure average current with a comparator to turn on MOSFET for CC mode with series storage inductor and clamp diode to make a buck regulator. This will make it oscillate, so inductor must be able to handle DC current. ( e.g. 50~100uH)
Voltage feedback also feedback to prevent over voltage with small filter.
When CC reaches 7.2V it goes into CV mode and a few seconds after CV mode, it checks if current is less than ~ 10% of max rated current, then can go into Float mode.
Generally VRLA's use a thermistor to compensate target voltages to prevent gassing according to Mfg specs.
Or look for a ASIC to reduce component count.
