exp
Full Member level 1
In a paper I found the use of an OTA+buffer ("opamp") as a baseband amplifier after the mixer. It uses resistive feedback and the source resistance is given by a series of the antenna and the switch impedance of the mixer. To first order, the amplifier can be descried as the ordinary "inverting opamp amplifier":
https://en.wikipedia.org/wiki/Operational_amplifier#Inverting_amplifier
with typical numbers from the mentioned paper: Rin=55 Ohm, Rf=2k, a0=30 (since it consists of a simple diff pair + source follower in a 65nm process).
Using these numbers I get a Gain of A0 = a0/(a0+1) * 1/(Rin/Rf + 1/(a0+1)) = 16 which is OK.
However, the loop gain is given as T = a0/(1 + Rf/Rin) = 0.8029 < 1 !
The approximation A0 = Rf/Rs is only valid if a0 >> Rf/Rs.
Now I am confused: I always learned the loop gain should be as high as possible for good accuracy, linearity etc.
Does it make sense to use an amplifier like this where the loop gain is even negative? (one advantage is that it is unconditionally stable).
Based on the T expression, it seems like the circuit requires Rin >> Rf (or extremely high a0).
Also, since the distortion coefficients are attenuated by (1+T), wouldn't a configuration like this be a desaster for linearity?
Or do I just miss something?
