MZulkarnain Jaranee
Newbie level 5
Hi Everyone,
I'm making an asynchronous pipeline which mean every stage of pipeline control by local controller, using Quartus 2, written in VHDL language. The problem i'm facing is unversity waveform program shown that the data is not transferred between stages as shown in below images. Below image is simulated from two stages pipeline. The function of the pipeline is FIFO.
D_out is the final output from the pipeline meanwhile, D is the output from stage 1 and is the input for stage 2.
after many attempts to fix, somehow I can figure out what is the problem.
Hopefully, anyone here can help/advice me.
Fyi, there is two state only in this pipeline.
State0 - transfer data between stages when stage1 is full and stage2 is empty
State1 - disable data transfer between stages when stage 2 is full and stage 1 is empty.
The state machine is written in the state_conductor.vhd file.
Here is the code
------------- top entity ---------------------------
------------- sub module -----
------------- gasp_ctrl.vhd ----- this module responsible to enable and disable the dflipflop in dfflop.vhd --------------
-------------- dfflop.vhd --- for store the data in stage
-----------------state_conductor.vhd----responsible either to transfer data between stage or no
CIRCUIT IMAGE
Here is the code
library ieee;
use ieee.std_logic_1164.all;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
entity gasp is
port(
x, y : in std_LOGIC;
d_in : in integer;
d_out, d: out integer
end gasp;
architecture gasp of gasp is
COMPONENT dfflop
port(
data_in: in integer;
enable: in std_logic;
data_out: out integer
END COMPONENT;
COMPONENT gasp_ctrl
PORT
in0, in1 : in STD_LOGIC;
en : out STD_LOGIC
END COMPONENT;
COMPONENT state_conductor
port(
in_left : in std_logic; -- - in_left is left bit for current_state
in_right : in std_logic; -- - in_right is right bit for current_state
state : out std_logic -- assert low or high bit for gasp controller
END COMPONENT;
---- state conductor wire ------
signal state_1: std_LOGIC;
------- enable wire ------------
signal en_1, w, en_2, z: std_LOGIC ;
------- data wire ------------
signal data_wire, data_wire1 : integer ;
begin
------------ stage 1 ---------------------
ctrl_1 : gasp_ctrl port map (in0 => x, in1 => state_1, en => en_1);
latch_1 : dfflop port map (data_in => d_in, enable => en_1, data_out => data_wire);
conductor_1 : state_conductor port map (in_left => en_1 ,in_right => en_2, state => state_1);
ctrl_2 : gasp_ctrl port map (in0 => state_1, in1 => y, en => en_2);
latch_2 : dfflop port map (data_in => data_wire, enable => en_2, data_out => d_out);
d <= data_wire;
end gasp;
library ieee;
ENTITY gasp_ctrl IS
PORT
en : out STD_LOGIC
END gasp_ctrl;
ARCHITECTURE structure OF gasp_ctrl IS
BEGIN
en <= (NOT in0) AND in1;
END structure;
library ieee;
entity dfflop is
port(
end dfflop;
architecture behv of dfflop is
begin
process(enable)
begin
-- enable rising edge ----
if (rising_edge(enable)) then
data_out <= data_in;
end if;
end process;
end behv;
library ieee;
LIBRARY work;
ENTITY state_conductor IS
PORT
END state_conductor;
ARCHITECTURE structure OF state_conductor IS
type STATE_TYPE is (S0, S1);
signal CURRENT_STATE: STATE_TYPE ;
signal NEXT_STATE: STATE_TYPE := S1;
signal full_empty : std_logic_vector(1 downto 0) ;
signal en : std_logic;
BEGIN
full_empty(1) <= in_left;
full_empty(0) <= in_right;
CURRENT_STATE <= NEXT_STATE after 7ns;
process(CURRENT_STATE, full_empty)
begin
case CURRENT_STATE is
when S0 => state <= '0';
if full_empty = "10" then NEXT_STATE <= S1;
else NEXT_STATE <= S0;
end if;
when S1 => state <= '1';
if full_empty = "01" then NEXT_STATE <= S0;
else NEXT_STATE <= S1;
end if;
end case;
end process;
END structure;
CIRCUIT IMAGE
