seyyah
Advanced Member level 2
I've designed a 24V 2.5A smps using powerint's top266eg chip using their reference designs. It works good normally. But if I connect a high capacity load that draws 5A at start-up but below 0.5A in normal condition, it enters short circuit protection and keeps restarting but cannot reach to stable condition. It has a soft start function that takes 17ms for this kind of situations but it seems not to be enough. I tried a commercial power supply with similar specs and with the same load and it works without problem. It draws a peak current of 3.8A or so at start-up. So I think I should slow down start-up process but I don't have an idea how to do it. What can I do for this problem? Any ideas? Thanks...
