Interfacing JHD162A LCD Module to micrcontroller
sathish316
Junior Member level 2
jhd162a
Im trying to interface a JHD162A LCD module to my at89c52 micrcontroller. As far as i find in micrcontroller textbooks LCD modules based on HD44780 are supposed to have 14 pins. but this ones got 16 pins. can anyone pls provide me the pin diagram or datasheet of this LCD. google returned a chinese site and the datasheet was not accessible.
tnx in advance
sathish
Added after 4 minutes:
I forgot to add that The LCD is a standard 16x2 LCD based on Hitachi HD44780 micrcontroller. It`s got 16 pins for interfacing. what are the other 2 pins for while any book on microcontroller suggests 14 pins for standard LCD modules.
lcd jhd162a
The last two pins are labelled LED+ and LED-.
That suggests to me they are for backlighting.
lcd jhd 162a
hi...
This JHD162A dosent have Hitachi controller but it has KS0070B controller from samsung. it has 16 pins
These are the pis
1 ---> GND
2 ---> VCC
3 ---> Vs (for contrast adjustment)
4 ---> RS
5 ---> RW
6 ---> EN
7 ---> D1
8 ---> D2
9 ---> D3
10 ---> D4
11 ---> D5
12 ---> D6
13 ---> D7
14 ---> D8
15 ---> VCC (Back light)
16 ---> GND (Backlight)
Regards
Sadashiv
Reactions: trnx geek
    trnx geek
    V
jhd162a lcd datasheet
I have this datasheet that i've downloaded from, www.datasheetarchive.com/, at the end of this archive has an example of code with coments in chinese. I hope you find it usefull!
jhd 162a lcd
an example of code with coments in Chinese
I translate code comment to English :
#include <reg51.h>
#include <intrins.h>
sbit dc=0xa0;     /*P2.0 LCD  RS  pin #21*/
sbit rw=0xa1;     /*P2.1 LCD  R/W pin #22*/
sbit cs=0xa4;     /*P2.4 LCD  E   pin #25*/
sfr  lcdbus=0x80; /*p0 LCD data bus D0=P0.0*/
unsigned int sys10mscounter;
unsigned char syslimitcounter;
// Self define font
char path1[8]={0x00,0x1f,0x00,0x1f,0x00,0x1f,0x00,0x1f}; // Horizontal 1
char path2[8]={0x1f,0x00,0x1f,0x00,0x1f,0x00,0x1f,0x00}; // Horizontal 2
char pats1[8]={0x15,0x15,0x15,0x15,0x15,0x15,0x15,0x15}; // Vertical 1
char pats2[8]={0x0a,0x0a,0x0a,0x0a,0x0a,0x0a,0x0a,0x0a}; // Vertical 2
void soft_nop(){}
void soft_10ms() // 12MHZ 10MS software delay
{    register int i;
     for(i=0;i<711;i++);
void soft_20ms() // 12MHZ 20MS software delay
{    soft_10ms();
     soft_10ms();
void hard_10ms(unsigned int delaytime) // delaytime*10MS hardware delay
{    sys10mscounter=delaytime;
     while(sys10mscounter);
unsigned char data lcdcounter;
bit lcdusing1,lcdusing2;
bit lcd_checkbusy()  // is LCD busy?
{register lcdstate;
    dc=0; // dc=1 -> data, =0 -> command
    rw=1; // rw=1 -> read, =0 -> write
    cs=1; // cs=1 -> selected
    soft_nop();
    lcdstate=lcdbus;
    cs=0;
    return((bit)(lcdstate&0x80));
void lcd_wrcmd(unsigned char lcdcmd) // write a character to LCD
{    lcdusing1=1;
     while(lcd_checkbusy());
     lcdbus=lcdcmd;
     rw=0; // rw=1 -> read, =0 -> write
     soft_nop();
     cs=0;
     lcdbus=0xff;
     lcdusing1=0;
void lcd_moveto(char position) // move cursor to position 0-79
{register cmd=0x80;
     lcdcounter=position;
     if (position > 59)
         position += 0x18;
     else
     {   if (position > 39) position -= 0x14;
         else
         {  if (position > 19) position += 0x2c;
     cmd = cmd | position;
     lcd_wrcmd(cmd);
void lcd_wrdata(char lcddata) // at surrent cursor write a character
{char i;
     lcdusing2=1;
     if (lcdcounter==20){
        lcd_moveto(20);
     if (lcdcounter==40){
        lcd_moveto(40);
     if (lcdcounter==60){
        lcd_moveto(60);
     if (lcdcounter==80){
        lcd_moveto(0);
        lcdcounter=0;
     lcdcounter++;
     lcdbus=lcddata;
     dc=1; // dc=1 -> data, =0 -> command
     soft_nop();
     cs=0;
     lcdbus=0xff;
     lcdusing2=0;
void lcd_string(char *strpoint) // at current cursor write a string
{register i=0;
      while(strpoint[i]!=0){
           lcd_wrdata(strpoint[i]);
           i++;}
void lcd_init()  //initialize LCD
     lcd_wrcmd(0x38); //8 bit data bus
     lcd_wrcmd(0x0c); //block cursor,non blink
     lcd_wrcmd(0x06); //don't move after display
     lcd_wrcmd(0x01); //Clear display
     lcdcounter=0;
void lcd_cls()  // clear LCD
     lcd_wrcmd(0x01);
     lcdcounter=0;
void timer0(void) interrupt 1 // T0 interrupt service routine
     TH0=0xd8; /*12M,10ms*/
     TL0=0xf6;
     TR0=1;
     if(sys10mscounter !=0)sys10mscounter--;  // 10ms timer
     if(syslimitcounter!=0)syslimitcounter--; // 10ms timer
main()
{unsigned char j;
     IE=0;P0=0xff;P1=0xff;P2=0xff;P3=0xff; // Initialize
     lcd_init(); soft_20ms();
     TMOD=0x51;
     TL0=0xf6;
     TR0=1;ET0=1;EA=1;
     while(1)
     // Display :
     // All black; horizontal 1; horizontal 2; vertical 1; vertical 2
     // UUUUUU...., QQQQQQQ.... ABCD...
     lcd_init(); // all black
     for(j=0;j<80;j++){lcd_wrdata(0xff);}
     hard_10ms(50);
     lcd_init(); // Horizontal 1 -> check font definition
     lcd_wrcmd(0x40);
     for(j=0;j<8;j++)lcd_wrdata(path1[j]);
     for(j=0;j<100;j++)lcd_wrdata(0);
     hard_10ms(50);
     lcd_init(); // Horizontal 2
     lcd_wrcmd(0x40);
     for(j=0;j<8;j++)lcd_wrdata(path2[j]);
     hard_10ms(50);
     lcd_init(); // Vertical 1
     lcd_wrcmd(0x40);
     for(j=0;j<8;j++)lcd_wrdata(pats1[j]);
     hard_10ms(50);
     lcd_init(); // Vertical 2
     lcd_wrcmd(0x40);
     for(j=0;j<8;j++)lcd_wrdata(pats2[j]);
     hard_10ms(50);
     lcd_init();
     lcd_string("UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU");
     hard_10ms(50);
     lcd_init();
     lcd_string("QQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQ");
     hard_10ms(50);
     lcd_init();
     lcd_string("ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789abcdefghijklmnopqrstuvwxyz0123456789+-!#$%&?");
     hard_10ms(50);
hi..
am extremely t hankful to "budhy"
the translated code helped me a lot............
i was working on it for 3 days.......it finally worked..the lcd sprung to lyf....
thanx a lot!!!
jakshay
Hi All,
Refering to this code,
May i know what is this hex number stand for and why we have to write like this. Is there any reference that i can refer to? I'm still new with this field and need ur expertise to explain it :) thanks :-
how to interface 89c51 to lcd jhd162a programme my name and circuit
I am having same problems with JCM162D.
Googling shows only Chinese forums.
Please help
someone of u please help me .........how to interface lcd(jhd 162a) with micro controller p89v51rd2bn
