They don't have to be the same but it makes the math simpler.why are resistor same values for sallen key filter when designing ?
Correct - however, does this justify the dimensioning with equal components?
I don`t think so - because this has severe disadvantages.
Selection of equal component values requires a fixed gain rater close to the stability limit (which is "3") and the filter parameter sensitivity upon tolerances is rather large.
A better design is based on unity gain or gain of "2" - with the consequence of unequal resistor values.
I am not sure when it was invented but the S-K filter was in common use in 1945
