How to consider the cmfb loop stability ?
ablue
Member level 1
stability of cmfb loop
Hi all:
if i use discrete time cmfb in my design, how to consider the cmfb loop stability ? will that be unstable? what is the difference between discretetime cmfb and continuous time cmfb in loop stability
Re: stability of cmfb loop
In P.R.gray's 4th edition analog circuit design book, there are some discussion on this issue. You can consult it.
to make stability when you make GBWcm>GBWdm
Is it really necessary to make GBWcm > GBWdm?
I did not bother much about SC CMFB loop stability when designed fully-diff OTA. Just followed the caps sizing considerations from Johns&Martin (swicthed caps should be 1/4~1/10 of non-switched), played a bit with PSS to see the CM level dynamics during the clock and it worked fine for me..
I think loop stability is a problem for continuous-time CMFB, not discrete.
You can see this paper
”Determination of stability using return ratios in balanced fully differential feedback circuits” IEEE transactions of circuits and systems II, vol 42, NO.12 DEC. 1995.
when stability
always check the loopgian T=a*f
you can use bode
I think GBWcm<GBWdm is better
layes2 said:
when stability
can u explain in detail?3x
you can use bode
What do you mean swicthed caps and non-switched caps?
