Results 1 to 5 of 5
    Points: 111, Level: 1
    Oct 2012
    Dark side of the sun
    7
    111
    Footprint does not show up in Allegro
    I am using Allegro 16.5. I created my own BGA footprint using the inbuilt Package symbol wizard (File -> New -> PAckage Symbol (Wizard)). However, I cannot seem to view it when I try to open it. When I open the symbol, the command window says "Opening Existing Design ..." and then goes to the command prompt. My screen refreshes but it refreshes to a blank screen.
    I modified the existing bgapad.pad padstack so as to include a soldermask on it. As such, I have two layers, the top and the top soldermask. Can someone help me out on this?
    Thank you.
    EDIT: Just as a FYI, I have ssh'ed to our university server (my univ. has the Cadence license so I have to run it from there). Could this be a problem because of that?
    Advanced Member level 2
    Points: 3,989, Level: 14
    Apr 2010
    Chennai,India
    615
    3,989
    14
    Re: Footprint does not show up in Allegro
    file--->open--->select your footprint name (.dra file format) as i mention in image file.(if want to open board file select .brd)
    kapil
    Points: 5,545, Level: 17
    Dec 2006
    India
    515
    5,545
    17
    Check the path of the footprint.This could be due to change in the location of bga footprint.
    Try File>>open>>and select file type *.dra as shown in above thread>> select the location of your footprint in file name.
    Oct 2012
    7
    111
    Thank you both for your replies. I'm sorry if I wasn't clear in my question. I have opened the footprint by selecting the file type as .dra and then clicking on the required footprint to open it. The command window says "Opening existing design..." and then shows nothing. A blank screen, same as BEFORE I clicked on File->Open->.dra file.
    Dec 2006
    India
    515
    5,545
    17
    did you tried opening any other footprint package?if it is problem in all footprints than you have to check library paths(padpath and psmpath) other wise there is issue with footprint try recreating it.
