tonionio
Newbie level 6
Hello everyone and nice to be here with you guys in such an interesting forum!
I would like to ask for advice. My project is to write a routing algorithm for a 64core chip using dimension order routing. In the beginning I should write something simple and then maybe implement other features in the algorithm in order to improve traffic distribution.
Each core's router will have 5 ports , 4 ports for east , south ,west, north and a local port for the processing unit.
I want to use as the title says x-y routing and write the code in VHDL as it is a safe way to get results. As i ve seen the most common tool is Verilog but I have some hands-on experience in VHDL so my supervisor said to go on that way.
The algorithm is going to be implemented on a board with 4 FPGA's each one implementing 16 cores (4x4) of the total 64 cores.
The project is all about delay of such a routing algorithm and comparison with delay of optical interconnects instead of wires.
Any suggestions to where I could find code or tutorials to begin the build for a router?
Any help and any suggestion is most welcomed.
Thank you in advance.
