cheekang
Newbie level 6
can somebody recommend me where to get atmega microcontroller burner with reasonable price in Malaysia? As for your information, this device is used for normal project which require simple function.
One of the simplest programmers you can make is http://electronics-diy.com/avr_programmer.php assuming that you have a serial port in your PC.
Then you can use this programmer to make a much better USB programmer http://www.fischl.de/usbasp/
On the other hand you can buy a USBasp programmer from ebay with a very low cost , less that $5 US including shipping.
In order to program the mega8 you need to connect the power supply (you can use the one provider from usb through the USBasp ISP output), connect a crystal or external clock if the clock source is changed from the default internal RC and connect the ISP pins.
USBasp output plug provides the RESET,+5v,GND, MISO, MOSI, SCK signals
