glenndingding
Newbie level 5
- Joined
- Feb 15, 2012
- Messages
- 10
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Philippines
- Activity points
- 1,403
hi everyone,
i am using MICRO C for my PIC16f877a micro controller but i have a problem encountered regarding the adc configuration and and making conditions in comparing constants.
i have 3 inputs which in need to be read in adc.....
1st input ...the adc read it. then it compares to a constant value of 12. then it gives 2 outputs. first output is switch relay and second output led blink.
2nd input ...the adc read it. then it compares to a constant value of 16. then it gives 2 outputs. first output is switch relay and second output led blink.
3rd input ...the adc read it. then it compares to a constant value of 24. then it gives 2 outputs. first output is switch relay and second output led blink.
here is my code .....please help me to correct..
..............the problems occur:
1. line 38 , 39, 40 .......too many parameters
2. line 46, .......;expected, but '6' found
3. line 46, .......'{' expected, but ';' found
4. line 95..........specifier needed
5. line 95........invalid declarator expected '(' or identifier
6. line 95.......internal error"
please help me to correct the configuration and the errors please
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 void ADCInit(){ //configuring adc module } unsigned int ADCRead(){ ADCON1 = 0xFF; //configuring AN0-AN7 as analog inputs and VREF ADCON0 = 0x07; //configuring analog channels AN0, AN1, AN2 ADON_BIT = 1; //switch on adc module GO_DONE_BIT =1 ; //start conversion while(GO_DONE_BIT); //wait for the condition to finish ADON_BIT= 0; //switch off adc } void main(){ ADCInit(); //initializes adc in the main program TRISB = 0x00; PORTB = 0x00; //putting port B as output for LED indicator TRISD = 0X00; PORTD = 0x00; //putting port D as output for relay switching while(1){ unsigned int sensor1_15A; //assigning variable for input1 unsigned int sensor2_20A; //assigning variable for input2 unsigned int sensor3_30A; //assigning variable for input3 unsigned int reading1; //assigning variable for adc reading1 for input1 unsigned int reading2; //assigning variable for adc reading2 for input2 unsigned int reading3; //assigning variable for adc reading3 for input3 reading1 = sensor1_15A-511*0.012207; //assigning variables with constants reading2 = sensor2_20A-511*0.012207; //assigning variables with constants reading3 = sensor3_30A-511*0.012207; //assigning variables with constants sensor1_15A = ADCRead(1); //the adc reading of input 1 will be placed in the first variable sensor1_15A sensor2_20A = ADCRead(2); //the adc reading of input 2 will be placed in the first variable sensor2_20A sensor3_30A = ADCRead(3); //the adc reading of input 3 will be placed in the first variable sensor3_30A while(1){ if (reading1>12){ // condition when the (adc reading-511*0.012207) is greater to the set value of 12 amperes //adc reading-511*0.012207 = amperes....... PORTD.6 = 0xFF; //port D is used fOr switching relay1 at RD6 at pin 29 of PIC16f877a is set to input for relay switching // I do not know if it is PORTD.6.. i consider RD0, RD1, RD2, RD3, RD4, RD5,RD6, RD7 = pin 0,1,2,3,4,5,6,7 PORTD.6 = 0x00; delay_ms(5000); //port D at at RD6 at pin 29 of PIC16f877a is set to output for relay switching PORTB.7 = 0x00; //PORT B AT rb7 at pin 40 of pic16f877a is set to output for led blinking delay_ms(1000); PORTB.7 = 0xFF; //PORT B AT rb7 at pin 40 of pic16f877a is set to input for led blinking delay_ms(1000); else PORTD.6 = 0xFF; //PORT D AT RD6 is nothing to do PORTB.6 = 0x00; //PORT B AT rb6 at pin 39 of pic16f877a is set to output for led steady light } if (reading2>16){ // condition when the (adc reading-511*0.012207) is greater to the set value of 16 amperes //adc reading-511*0.012207 = amperes....... PORTD.5 = 0xFF; //port D is used fpr switching relay2 at RD5 at pin 28 of PIC16f877a is set to input for relay switching // I do not know if it is PORTD.5.. i consider RD0, RD1, RD2, RD3, RD4, RD5,RD6, RD7 = pin 0,1,2,3,4,5,6,7 delay_ms(5000); PORTD.5 = 0x00; delay_ms(5000); PORTB.5 = 0x00; //PORT B AT rb5 at pin 38 of pic16f877a is set to output for led blinking delay_ms(1000); PORTB.5 = 0xFF; //PORT B AT rb5 at pin 38 of pic16f877a is set to input for led blinking delay_ms(1000); else PORTD.5 = 0xFF; //PORT D AT RD5 is nothing to do PORTB.4 = 0x00; //PORT B AT rb4 at pin 37 of pic16f877a is set to output for led steady light } if (reading3>24){ // condition when the (adc reading-511*0.012207) is greater to the set value of 16 amperes //adc reading-511*0.012207 = amperes....... PORTD.4 = 0xFF; //port D is used fpr switching relay3 at RD4 at pin 28 of PIC16f877a is set to input for relay switching // I do not know if it is PORTD.5.. i consider RD0, RD1, RD2, RD3, RD4, RD5,RD6, RD7 = pin 0,1,2,3,4,5,6,7 delay_ms(5000); PORTD.4 = 0X00; delay_ms(5000); PORTB.3 = 0x00; //PORT B AT rb3 at pin 36 of pic16f877a is set to output for led blinking delay_ms(1000); PORTB.3 = 0xFF; //PORT B AT rb3 at pin 36 of pic16f877a is set to output for led blinking delay_ms(1000); else PORTD.4 = 0xFF; //PORT D AT RD4 is nothing to do PORTB.2 = 0x00; //PORT B AT rb2 at pin 35 of pic16f877a is set to output for led steady light } } } }
