varunkant2k
Full Member level 6
Hi all,
In my evaluation chip of Hbridge driver, I am seeing big oscillation at the gate drive signal (which is driving PMOS and NMOS switches of HBRIDGE). HBridge is meant to drive maximum of 3A load and is driven maximum of 50V supply.
So my HBridge switch sizes are too big, and gate capacitance can be assumed more than 300pF.
Please suggest the reason behind the oscillation ( I understand due to "Pad and wiring inductors"). How to remove these Oscillation? I see maximum oscillations peak when no load, and reduces with increased loading?
If I add capacitor across supply and gate node for PMOS switch, they are suppressed, but we can't consider that big capacitor ( going to be costly).
Your any insight in the problem that may help me to look at the problem.
thanks in advance.
thanks in advance.
