+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Junior Member level 1
    Points: 473, Level: 4
    Join Date
    Jan 2012
    Israel
    Posts
    17
    Points
    473
    Level
    Total Radiated power (TRP) equation
    Hello all,
    I wanted some clarification regarding the addition used in the discrete form of the TRP equation (used in anechoic chambers, see image below).
    Click image for larger version.
    Does the EIRP or Gain addition is a vector addition?
    I think it should be, althogh the equation representation does not look like a vector addition.
    As much as I understnd, the addition should be : SQRT(EIRP(THETA)^2+EIRP(PHI)^2).
    •   AltAdvertisement
  2. #2
    Join Date
    Jan 2012
    Israel
    Posts
    17
    Points
    473
    Level
    Re: Total Radiated power (TRP) equation
    Found this:
    "In practice, the total EIRP will likely be measured at each sample point by measuring its two
    orthogonally polarized components, EIRPθ (θ , φ) and EIRPφ (θ , φ). To accommodate this
    measurement practicality, we can split the radiation intensity at each angle into two
    contributions, one from each polarization (power in independent components simply adds)"
    •   AltAdvertisement
  3. #3
    Banned
    Points: 2,420, Level: 11
    Join Date
    Feb 2008
    Posts
    244
    Points
    2,420
    Level
    11
    Good.
    You found answers to your own question.way to go!
    Regards
    Rotmanlens
    •   AltAdvertisement
  4. #4
    Join Date
    Jan 2012
    Israel
    Posts
    17
    Points
    473
    Level
    Yes, I waited but no one answered. but still there is a question, why?
    To the best of my knowledge the E field is a vector which is projected on to the two orthogonal θ and φ axis.
    So, if this is the case the vector addition of this two projection will give the total E field and not a scalar addition of them.
  5. #5
    Join Date
    Jan 2012
    Israel
    Posts
    17
    Points
    473
    Level
    Found the answer. vector addition is really needed for the E field, but it can be shown that the power is a scalar addition of each component of the E field.
