ADC 0808 with 89c51 controller is it right?
samm
Newbie level 1
we are using 0808 IC for AD conversion (with microcontroller of 89c51) but it is not responding precisely why?
Check your reference voltage if at the correct value if there is an error on binary equivalent readings.
Dear samm,
you are trying to connect 0808 to the AT89c51 ok, which port used ?
and how u will see the o/p (over the serial port or seven segment, ..)
Can you give me more information about your design
So I can help you to find the problem
Thanks
