Your assumption does hardly comply with the know property of a transformer respectively inductor to have zero average DC voltage across it.as far as i know the voltage at top switch wrt to center tap should be +28v-0v.but the voltage is +/-28v.
O.K., I understand the phase modulation idea. Basically, it's another way to implement a sine PWM. I assume, the ramp voltage range is -2V to +2V? Personally I would prefer a more reliable method than clocking the DFF with the comparator output, but it should work if designed properly. Any questions left?please go thru uspatent 4479175
