vanan87
Newbie level 1
i had bought SDA04M secugen stand alone finger printmodule.In data sheet they gave only pin details,they didnt gave working.In the module there is 2 i/p pins for connecting external switches.I dont know whats the use of that switches.also i dont know the commands to send through serial port from controller to the finger print reader,for capturing,deleting,verifying finger prints.
Module -SDA04M,Finger print reader -SDPB04,Optical module - SD0PP03M,Part number- EA4-0106A,I also attached specification below
CPU 533 MHz ARM
Flash 128 MB
User Capacity 10,000
1:1 Verification Time 0.1 sec
1:N Identification Time 0.2 sec
Enrollment Time 0.9 - 1.3 sec (capture + extraction)
Fingerprint Template Proprietary (400 bytes), ANSI-INCITS 378-2004 (variable size)
Supply Voltage 3.3V DC
Operating Current Consumption 110 mA
Max Current Consumption 380 mA
Communication Speed 921600 BPS (max)
Host Communication Serial (RS 232, TTL)
External Interface Weigand output, GPIO input (2), GPIO output (2 relay, 2 sw)
Optic Module SDOPP03M
Image Resolution 500 dpi
Image Size 260 x 300 pixels
Image Gray Scale 256 shades (8-bit gray level)
Non-Linear Distortion ~0%
Effective Sensing Area 12.7 x 14.9 mm
Platen Hardness 750 Hk (~6.8 Mohs)
Light Source Red LED
Typical Lifetime 60,000 hours
Ambient Light Tolerance 5,000 Lux (50,000 Lux with Smart Capture)
Dimensions 21 x 32 x 62 mm (optic module), 59 x 43 x 8 mm (PC board)
Operating / Storage Temp. - 20° to 65°C / - 40° to 85°C
Humidity 90% RH or less
ESD Tolerance 13 kV
FAR and FRR Read our FAQs
Other features Auto-On™
reply for this
CPU 533 MHz ARM
Flash 128 MB
ESD Tolerance 13 kV
reply for this
