PCB Driller made with the lowest possible price
B
BlackMamba
Project by m-a-r-i-o
Source here
Driller presented here allow to drill pcb’s with the bit as thin as 0,2mm. Drill chuck has no runout so bits are not broken. Drill chuck was bought here:
Uchwyty z kompletem zacisków, D-1504, D-1508
The lamp is placed on the top for the convenience. It is a limiter for the current taken by the motor. Without that lamp motor is rather hot, and I do not want to use a voltage regulator.
Time to drill a hole with a 1 mm drill is below one second, so power of the motor is satisfactory.
The target of this Project was to reach the lowest possible price.
