NMOS bulk connection - (2 wells: twell inside nwell)
sw0ws1
Junior Member level 1
My problem is the bulk connection of nmos because my nmos is located in two wells, twell and nwell,
the twell is located inside the nwell (as i upload here) ,my question is
1-i think the twell is the bulk of the nmos/is this true??
2-how i connect the bulk of nmos(twell) to its source ( i have no contact named
M1_twell but i have M1_Nwell, M1_poly, M1_Pdiff, M1_ndiff )??
3-when i try to put a M1_pdiff contact in the twell ,it causes DRC errors (like diff to diff min disance, ..)???
thanks in advance
Re: NMOS bulk connection
What's doping type for twell? P-type or N-type?
logically i think the doping of twell is p-type to form NMOS but i don't know this is true or not??
thanks in advance
Hi sw0ws1,
you seem to be trying to generate a triple well NMOS (also known as a deep-N-well NMOS); in all PDKs I have dealt with, the N-well layer is a ring partially overlapping TW (not a rectangle), are you sure your process requires using a rectangle?
Also usually the TW identifies the deep (N)well implant that creates the isolated P-well for the NMOS: basically the isolated pwell (that some foundries call RW) can be thought as a box whose bottom face is TW and whose side faces are NW (the top face is the silicon surface)
When contacting the body of the isolated NMOS you just need a p-contact to RW (M1_Pdiff in your case), of course you need to make sure you have enough room to avoid DRC violations
Please note NMOS' bulk will be P-type always.
thanks for all of u the problem is solved
i used M1_pdiff contact and add new twell and nwell to avoid the DRC errors....
thanks again
I just hope you understand the structure or you might end up with incorrect LVS....
