burnt ic identification
jmindler
hello all,
my son installed is car stereo, but he connected the power wires the wrong way. now the stereo does not work. I took it apart and found a what looks like a burnt ic. it has eight legs and the markings that I can make out are like this.
I R P647H
T1L6
F7205
any ideas.?
thanks
Can you upload a clear picture?
I wish I could. All you can see in the picture is a black square.
---------- Post added at 20:51 ---------- Previous post was at 20:33 ----------
Photos attached
You need to turn off the camera flash and use another bright light at a different angle. Sometimes wetting the surface with some alcohol will help differentiate the markings enough to read. Use the macro or close up setting on the camera if it has one.
Thanks again. It is almost impossible to see any markings. I was able to make out the letters and numbers in the post before with a magnifying glass and bright light. The burning makes it hard to read the markings.
this is a standard Mosfet in SO8 package.
Manufacturer: IR (International Rectifier)
PartNo: IRF7205
Datasheet: here
Any recommendations on where to get a new part? Thanks
Thanks for the help. I ordered the part last night. I was going to use a small soldering pen to remove and reinstall. Is that the best method? Hopefully, this will repair his radio issue. A lesson learned about polarity :)
You want to use a soldering tip that is slightly thinner than the component lead if possible. You need to have solder wick and know how to use it. To avoid having to heat all leads simultaneously to remove the chip, it's often easier to cut the leads off one at a time near the body of the chip with small wire cutters or carefully with a knife. After that you can use the soldering iron and solder wick to pick up the individual leads and clean the lands to prepare for the new chip.
This video is a good tutorial on beginning surface mount soldering: YouTube - Chaîne de CuriousInventor.
Be sure to orient the chip with pin 1 at the correct end.
