priestnot
Member level 5
Hello...
I am trying to build a fpga configurator in java. It will create the verilog files based on a text file created by the user witch tells the software witch modules to use. So the user just need to synthesize the toplevel in the ISE.
I wold like to know if some one knows were the ISE project folder the ISE stores the paths to the verilog sources of the project so i can edit them outside ISE...
I tried the projectffolder/toplevel.prj (and it is changed when ISE opens the project)
I also tried the projectffolder/FPGA_Core_xdb/tmp/ise/__REGISTRY__/ProjectSeedData/UserSourceFiles/regkeys (and it is also changed when ISE opens the project)
I realy hope that is not on the .ise binary file...
