+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Newbie level 1
    Points: 380, Level: 4
    Join Date
    Nov 2010
    Posts
    Points
    380
    Level
    IAR c compiler (msp430) - pointers help
    Hello, I'm using IAR C/C++ Compiler for MSP430 5.10.1 (5.10.1.50144)
    with the MSP430F2617 MCU.
    I have a problem when using pointers:
    when i try to debug the program with the following part of code, the debugger "hangs" (it takes a while till the iar changes to debug mode and then i don't have any option available accept 'stop debugging' "
    the problematic part:
    char pic0[2500], pic1[2500], *pic_rd, *pic_wrt;
    pic_rd = pic0;
    pic_wrt = pic1;
    however, when i'm using only one command:
    pic_rd = pic0;
    or
    pic_wrt = pic1;
    the debugger works fine.
    what could be the reason?
    •   AltAdvertisement
  2. #2
    Points: 11,875, Level: 26
    bobcat1's Avatar
    Join Date
    Jul 2002
    Posts
    Points
    11,875
    Level
    26
    Re: IAR c compiler (msp430) - pointers help
    Hi
    Don't use large array size with IAR decrease size or use union to divide the array to a smaller size section's
    All the best
    Bobi
