x3.exe
Member level 1
can anyone suggest a way to transmit streaming data from a microcontroller to a PC at 1Mbps ? I've tried using FT232RL chip, but in some cases blocks of data are lost, I think it is due to low interrupt priority of serial ports on modern PCs. At the moment I am using an SD card for storing data at first, and then sending it to PC at maximum allowable data rate, 3Mbps. It works, but isn't too efficient, as only 2 MB of memory out of 512 are actually used. I was thinking of using another type of memory for that purpose, but I am not sure which one. I considered Atmels serial flash with SRAM buffers, but I have doubts about the maximum supported data rates of serial flash. Can anyone suggest a better way to buffer the data before sending it to PC?
