AreaIO : what are pros and cons
mzquarter
Newbie level 3
Canada
Hi all,
I've read a little about AreaIO in contrast to peripheral IO in the Encounter documentation. Although they say how to use the different types, and mention differences, I didn't find anything on the differences on design impact. I also can't figure out if it is better to get a pre-built AreaIO library, or if it's "easy" to simply modify a peripheral IO library (and potentially making them smaller?).
So my question is two folds : What are the pros and cons of AreaIO, and how can I get one (if I prefer it over peripheral IO), supposing I already have a peripheral IO library (foundary sponsored ARM IOs).
The way I see it, AreaIO should be advantageous for flip chip designs. Instead of routing the bumps to the periphery, the signal would simply fall through vias to the AreaIO structure directly below. The power grid could then have its VDD and GND connections spread out through the entire chip, probably helping control IR drops and such. Is this correct?
Thanks
