geek12
Newbie level 2
Someone designed a circuit some years ago which employs a rectifier (half wave rectification) switched by a Solid state relay and fed to resistive load. The system was working fine for some time but now we are noticing diode blown up badly. I started investigating and thought coz diode was burnt it could be temperature related problem so found that amibent and surface temperature was well above 80C.But I believe rectifer which we are using can withstand 150c. Any idea why a rectifier will blow up (seriously burnt) without blowing any fuses? Also would it make any difference where the connections are made ? Any suggestions are welcome?
