jiripolivka said:Dear htg,
yes, you can. Probe diameter only affects its impedance; probe length is important and should be adjusted for a minimum loss of your transition.
davenn said:the probe length,as discussed in another topic for 150MHz by hgt myself and others should be an electrical 1/4 wavelength
Dave
htg said:Thanks, Dave. Can you give me an idea of bandwidth that I can expect at 150 MHz if I use 2 mm to 3 mm diameter probe?
htg said:Regarding the power (several kW level) at 150 MHz, ohmic losses may become significant. Should I use litz wire for the probe?
