"Endian" in Processors?
Little Endian and Big Endian, is the way that the processor stores data in the memory.
When you have data that is bigger than 8 bits, for example:
int data=0x1234; // 16 bits long
long data1=0x12345678 // 32 bits long
If your processor is big endian, the data will be stored in memory as:
int data = 0x1234
Dir 0 = 0x12
Dir 1 = 0x34
long data1 = 0x12345678
Dir 0 = 0x12
Dir 1 = 0x34
Dir 2 = 0x56
Dir 3 = 0x78
But, if the processor is Little endian, data will be stored as
int data = 0x1234
Dir 0 = 0x34
Dir 1 = 0x12
Dir 0 = 0x78
Dir 1 = 0x56
Dir 2 = 0x34
Dir 3 = 0x12
Hope it helps you
