pervanah
Newbie level 6
hi
i'm in an ASIC design project .
synthesis is done by synopsys design compiler .
placement and routing by first encounter.
we use standard cells of tsmc 90nm
calibre is used for verification (DRC/LVS/PEX)
when i try to run LVS : it flags this error
error:no module for cell <cell_name> ( it flags the same error for all cells)
WARNING: Cell CLKINVX1 is referenced but not defined. Empty cell used.
then the run is aborted with error =" can not read source"
my question :
how to correct this?
what are exactly the required tech. files ( other than the golden_rules svrf file?) .. how to add the lef files used and .db files used in the syntehsis and layout (first encounter layout generation) to calibre ?
thx
my question :
thx
